Slinger Posted November 26, 2009 Share Posted November 26, 2009 http://omgwtfbbq.ovh.org/gulf_en.htm The original article came from here: http://pclab.pl/art39718.html but Intel's lawyers made a phone call to pclabs and they had to pull it....Someone cached the article and posted however Enjoy Link to comment Share on other sites More sharing options...
DanGrover Posted November 26, 2009 Share Posted November 26, 2009 Niice. It appears to run very cool, too. And this is an early sample version, too! Looks impressive, but presumably it'll be fairly costly. Mind you, with a pair of these in the trunk, you're looking at 24 HT cores. It would be costly. Link to comment Share on other sites More sharing options...
Koza43 Posted November 26, 2009 Share Posted November 26, 2009 (edited) I wish the cost of xeons go down. Will rather go for two xeons than 1 gulftown... DanGrover thx for diagramm if it's correct. Is there any info of i9's stock power consumption on full 100% usage ? it's 32nm. it would be lower than i7 I presume, but want to know how much lower. Edited November 26, 2009 by Koza43 Link to comment Share on other sites More sharing options...
DanGrover Posted November 26, 2009 Share Posted November 26, 2009 I wish the cost of xeons go down. Will rather go for two xeons than 1 gulftown... DanGrover thx for diagramm if it's correct. Is there any info of i9's stock power consumption on full 100% usage ? it's 32nm. it would be lower than i7 I presume, but want to know how much lower. If you check out the first link, there are loads of details, inc these two graphs... and for temp... Pretty nice temps! Link to comment Share on other sites More sharing options...
Slinger Posted November 26, 2009 Author Share Posted November 26, 2009 I wish the cost of xeons go down. Will rather go for two xeons than 1 gulftown... DanGrover thx for diagramm if it's correct. Is there any info of i9's stock power consumption on full 100% usage ? it's 32nm. it would be lower than i7 I presume, but want to know how much lower.Click on the first link I posted and go almost to the bottom...they have graphs showing wattage and temp at idle and load. Link to comment Share on other sites More sharing options...
Koza43 Posted November 26, 2009 Share Posted November 26, 2009 Oh no! I haven't seen your 1st post. Yes indeed everything is in the first link. Sorry, Guess I was tired. Thanks for the link. Really plenty of info. Sorry again. Link to comment Share on other sites More sharing options...
Tommy L Posted November 26, 2009 Share Posted November 26, 2009 Does the i9 go in the same socket as the i7? Link to comment Share on other sites More sharing options...
Slinger Posted November 26, 2009 Author Share Posted November 26, 2009 (edited) I believe they are socket 1156 but the articles states they are backward compatible with socket 1366(i7) From article:"Gulftown processors are backwards compatible with the LGA 1366 socket. The only thing you need to do to run them on today’s motherboards is a BIOS update." Edited November 26, 2009 by Slinger Link to comment Share on other sites More sharing options...
Tommy L Posted November 26, 2009 Share Posted November 26, 2009 groovy, shame theyre not compatible with socket 775(?) or Id upgrade the farm from q6600's. Link to comment Share on other sites More sharing options...
