floor material vray
c@du
Hello guys.
First of all, i would like to thanks to this comunity for beeing so helpful. Every time i have doubts about a specific problem, i google it, and almost always end up here, where my problems are solved.
I´ve been around here for some time, but this is my first post, since i can´t find the right answer. So here it goes.
I´ve noticed that on a ceramic tiled floor, the reflections have some kind of break between the diferent tiles. I´ve been wondering how i could achieve this effect with vray materials.
Sorry if the english is not correct. i atached an image for a better understanding of what i´m refering to.
Thanks in advance to all of you.
p.s - Fro my understanding, this happens because the base flloor isn´t planar, it has minimal different heights, and that´s what causes the irregular reflections, but how to translate that to the material without having to change the mesh.
Edited by c@du
As above is the right way to go but something must not be working.
You could use a tile map and change the color variance parameter which will give each tile a slightly different grey value. You could even plug in a gradient into the tile slot to give each tile a little bit of tilt.
Ok, thanks. That´s exactly the aproach i took.
I used the colour variance of a tile, mixed with other tiles in order to have a different shade on the different parts. I also used a gradient ramp to have a smooth bump in the outer parts. But it didn´t work.
So, i must have missed something. Now that I´m sure this is the right way, i will no lounger waste my time trying different techniques, and i will concentrate on this one.
Thanks
Hi, WAcky.
I found the Problem. I didn´t had enough diference in the tiles. As soon as i increased it, the effect started to show up.
But what made a huge difference was your advice on the gradient, wich made the final effect more convincing.
For the gradient i used a composite material. First layer a checkered tile with a soft gradient. Then i used a second layer with the gradient in an opposite direction. Finally the last layer has only the division between the tiles wich is the stronger bump.
I´m wondering if it wasn´t better to build this map in photoshop, and use only one bitmap for the effect.
One side proceduals, on the other side a bitmap.
One more time, thanks for your help and precious advices.
I had the same problem. I had the tile subdivided by 4x4. I was trying to have different variation along the tiles, but i had a hard time. So i swicthed the tile for 2x2, and this way i could have more control over the maps.
But, i think that Wacky solve our problem with the bercon maps.
The way i did it, in order to have more variation i had to use more maps, and a lot more time consuming.
Thanks to wacky again.
