For my information
Sawyer
This is something that is really a big thing here at our office but I have seen it done other ways.
When drafting do you use wall dimensions of 2x4 or 1 1/2 x 3 1/2 (nominal or actual)? We use actual but I have worked at other offices that use nominal and we often get work from other offices that use nominal.
Just kind of curious.
i don't know about our firm, since i have never drafted for them, but what advantage would you have by using the nominal dimension instead of the actual dimension? a half an inch by itself can be a lot of error, much less a half inch mulitplied several times.
..also, can anyone tell me why there are nominal dimensions, and actual dimensions? i don't know, i am just curious.
*edit ..i know back in the day that 2x4's were 2x4's, but why did they become smaller? ...were the old ones overdesigned? ...to save cost? ...??
The resoan behind nominal and actual is due to the process of milling the lumber. They cut the lumber at nominal sizes, however, after it goes through the drying process, it shrinks a tad. In respect to drawing nominal vs actual; a contractor will kill you if you tell them they have to be within a half of an inch on a wall, nonetheless a quarter of an inch. Its like drawing block wall. You show a CMU wall at 8in x 16in. But the actual measurement is like 7 7/8 x 15 3/4. Once they put the grout in, it makes up for the 1/4in. difference. Hope it helps.
