Irradiance pre calc problem
dougvanderpas
Hey,
Having a problem with a fly-through. Tried a few things and read a few forums but it doesn't seem to solve my problem.
I'm on Vray 1,50 SP3
I am pre calculating my irradiance. I have tried "multiframe incremental" and also the "animation pre-pass". I'm rendering every nth frame (10th). I'm setting my secondary bounce to none. My "don't render final image" is checked. It seems to calculate as expected.
When done I load my irradiance from my saved location. un-check my "don't render final image" and flip my nth frame back to 1.
I wanna use a light cache for secondaries, so for now I'm just gonna calculate per frame.
I render and get a dark image!! When I render and calculate single frame it works fine.
I was using "distributed rendering" and then found out that this was not compatible when pre-calcing irradiance. so then i tried calculating locally but with the same result.
The only time I get my illumination correct is when I calculate per frame but this is leading to flickering.
I enclosed an image. It actually looks like the light cache is off but I assure you that it is on and it appears to be calculating as normal.
Your help would be appreciated! cheers
