vizwhiz Posted June 29, 2003 Share Posted June 29, 2003 hi There check This out (and let me know if it works) **** from CADdepot.com update newsletter "Applying Customization: Right-Click Menus in LISP - AutoCAD tutorial on using the right-click capability to respond to prompts, Dave Pitzer, Autodesk.com" http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=3369298&linkID=2475176 the original is: (defun c: what ;;;etc bla bla bla .... ) so check This out i couldnt resist Tinkering with the original code by Dave Pitzer **** This is my version i renamed it to be 3d-doit.lsp **** (defun c:3d-doit (/ qaz) (initget 1 "B C L P R AR CO ER MO RO SC BX CX LX PX RE SB SL SU T U X XT") (setq qaz (getkword "Draw 3d do-what: [/Bpoly/Circle/Line/Pline/Rectang//ARray/COpy/ERase/MOve/ROtate/SCale//BoX/bPolyX/CircleX/pLineX/REctang//SUbtract/Union/inTersect/SLice/SBlice/eXtrude/eXTrudelast]:")) (cond ;;;2d-doit commands go here ((= qaz "B")(command ".bpoly" pause "")) ((= qaz "C") (command ".circle" pause pause)) ((= qaz "L") (command ".line")) ((= qaz "P") (command ".pline")) ((= qaz "R") (command ".rectang")) ;;;2d-edit commands go here ((= qaz "AR")(command ".array")) ((= qaz "CO")(command ".copy")) ((= qaz "ER")(command ".erase")) ((= qaz "MO")(command ".move")) ((= qaz "RO")(command ".rotate")) ((= qaz "SC")(command ".scale")) ;;;3d-doit commands go here ((= qaz "BX")(c:321)) ;;;(command ".box") ((= qaz "PX")(progn (command ".bpoly" pause "" "") (command ".extrude" "L" "" pause "" 0))) ((= qaz "CX")(progn (command ".circle" pause pause) (command ".extrude" "L" "" pause "" 0))) ((= qaz "LX")(progn (command ".pline") (command ".extrude" "L" "" pause "" 0))) ((= qaz "RE")(progn (command ".rectang" pause pause) (command ".extrude" "L" "" pause "" 0))) ;;;3d-edit commands go here ((= qaz "SL")(c:342)) ;;;(command ".slice")) ((= qaz "SB")(c:343)) ;;;(command ".slice")) keep Both option: ((= qaz "SU")(command ".subtract")) ((= qaz "T") (command ".intersect")) ((= qaz "U") (command ".union")) ((= qaz "X") (command ".extrude" pause "" pause "" 0 "")) ((= qaz "XT")(command ".extrude" "L" "" pause "" 0)) ) ) **** some of the options reference my own numerical alias system just replace the front end #'s with the trailing code fragments Thanks Randy Link to comment Share on other sites More sharing options...
