M_A_B Posted December 5, 2009 Share Posted December 5, 2009 Hi guys, I recently got some of the evermotion files and was wondering how i can use the lighting and textures to make my work look as good, i havent been able to figure it out yet any help will be much appreciated. Link to comment Share on other sites More sharing options...
raq007 Posted December 5, 2009 Share Posted December 5, 2009 if u have any evermotion scene where u see light, texture etc. simply select ur any light then under command panel slect Modify button where u'll see every setting of that light which evermotion has made.. there u can comparison with the same light which has default setting.. same like about texture.. open ur Material editor and where u'll see Eey droper select it and click on ur any model in scene u'll see model's material will appear in material slot then click on that slot u'll see every setting of material in material parameters.. i hope thats what u were asking about.. Link to comment Share on other sites More sharing options...
braddewald Posted December 7, 2009 Share Posted December 7, 2009 Be careful trying to mimic evermotion's scene setups. Sometimes they use wacky settings and methods for their render setup, materials and lighting. There was a thread started a couple days ago that mentions this problem. I think this is it. Try just looking around at where they have the lights and everything. If you want to use a material from the scene you can use the eyedroppper as raq007 said to pick the materials and modify them. Pay close attention to everything though. They use fresnel on a lot of their materials and sometimes odd IORs. Link to comment Share on other sites More sharing options...
