Clive Edwards Posted December 10, 2009 Share Posted December 10, 2009 I have looked at all sorts of web sites and tutorials and I am unable to find anything close to a step by step guide(idiots guide in my case) to matching the camera view to a site photograph. Judging by the quality of the work posted it's hard to believe that this is all done by trial and error. What I have done is to load an image into the camera view and then try to match up the perspective of the camera view to the photo. Sometimes it's ok other times not. Does anyone have any advice as to where to go to get some better info. Any help much appreciated. Clive Edwards Link to comment Share on other sites More sharing options...
kippu Posted December 10, 2009 Share Posted December 10, 2009 (edited) havenot seen or heard anyone practice camera match in reality really ...it was way complicated when i tried ... now its all drawing perspective lines and making sure they all match , or thats how i do it .. there was just another thread on the same topic oops sorry , i did not notice the lightwave part Edited December 10, 2009 by kippu Link to comment Share on other sites More sharing options...
JonRashid Posted December 10, 2009 Share Posted December 10, 2009 I'm not sure where there are any tutorials but it's pretty straightforward if you understand the principle and will help where people have used not standard lenses etc. Take between 6 measurements of existing objects on the image that you can place accurately within your model. These should be in at least 2 planes (not all on 1 gable end wall for instance. I then create an image of the photgraph with these points marked clearly. Depends on your viewpoint resolution but clear enough to see as bgd. You then create these same points on your model. Carefully match the points (by number) in your viewport on the background. ie point 1 on model is same point 1 on image. Then solve. You may have to tweak some points if you havent been accurate but results are usually pretty good. Link to comment Share on other sites More sharing options...
kwi Posted December 10, 2009 Share Posted December 10, 2009 http://www.cgarena.com/freestuff/tutorials/max/lexus/index.html This tutorial is in MAX but this helped me understand Camera Match better. Link to comment Share on other sites More sharing options...
Clive Edwards Posted December 10, 2009 Author Share Posted December 10, 2009 Thanks for the replies. Jon, are you saying that in the camera view you keep altering the camera's properties,position rotation FOV etc to match the points up. Thanks Link to comment Share on other sites More sharing options...
JonRashid Posted December 10, 2009 Share Posted December 10, 2009 No you move the markers in the camera view then solve. I only tweak the actual camera once max has got a good solution Link to comment Share on other sites More sharing options...
thatch Posted December 10, 2009 Share Posted December 10, 2009 You should check out Syntheyes, you can do single frame alignments from a photograph. specify a couple of lines in xyz and it will match the camera position and fov, then export to lightwave. Takes no time at all and the program is really cheap for the time you will save. http://www.ssontech.com/content/aligner.htm Link to comment Share on other sites More sharing options...
