Confued on UCS
David Barbarash
I've recieved a drawing from another office and have encountered this problem before... When entering new text, whether it's an mtext, single line, or part of a qleader, it gets rotated to a set angle. There is obviously a way to change thi sback to align with the 0-180 degree axis. Please help as I seriously don't want to hand rotate every damn qleader I make for this HUGE mall site in RIchmond VA. Especially since I have limited time to finish it. Thanks in advance.
David Barbarash
Thanks for the reply. I think that thats the problem in the first place. The creator of the file has somehow set the world UCS to be at an angle. I've since figured out how to rotate the UCS along the Z axis in order to return the X and Y to their default alignments, but to me, It's only a temporary fix. Anyone know how to set the world UCS's rotational alignment? Ugh, I've just confused myself again.....
David Barbarash
World UCS can't be altered, custom UCS's can be created to your heart's content though.
My guess is that a new UCS was created to allow the building to be drawn parallel to the screen, whilst making it simpler to plot the dwg alligned to North.
To get the World UCS, do what Jeff said, then type plan and the drawing will be diplayed properly with regard to the world UCS. If this isn't having the desired effect, type UCS, then ? and then hit enter on the final prompt. This will display the names of the saved UCS's.
Type invoke UCS again, then R (for restore), then type the named UCS that you think is the correct one.
  • 2 months later...
Is the problem just with text? If it is then, the problem is in the style of the text. Check your text style.
If it is all, then it is the UCS. Easiest way to realign it is to type UCS, E(for entity) then select an object to align to. Type PLAN, enter, enter to rotate the view.
If it is the rotation angle, then it might be the set to Clock Wise. Goto Format, Units to reset the rotational angle.
Hope this helps.
hi There
David
set your UCS to the desired orientation
then grab all of the Text
d*mn cant use the parentheses on this bbs i just spent 20 minutes typing a reply and it all got #*$^#%$*@# wiped out
use the CHT command ChangeText then select R=rotate and enter 0 for the angle
ok
command: select
objects: >>>
then you can enter
command: cht
objects: !xx
rotate: 0
command: enter
let me know if This works
i cant believe how much Time i spent (it previewed ok) then the entire previous effort got wiped out when trying to post it
Thanks
Randy
This is not a good week to be Turkey
"o well, its only Life i will get a real-one The Next Time"
hi There
oops, found my own Typo
command: select objects: >>>
This should actually read:
The only difference is the traling " in "*textlyrs*" where *textlyrs* is whatever Text layers that you are selecting
just a Typo, a hypo Typo
i guess no one actually Tried That,
'cause it wouldnt have worked right
oops. did it again and That aint no
you have to have matching balanced pairs
in AutoLisp
Thanks
Randy
  • 4 weeks later...
  • 2 months later...
