Annoying dotted selection outlines.
braddewald
Ok so when you select something in photoshop it puts up these crazy dotted outlines that are "moving" around your selection area. Its good for knowing what exactly I have selected but very very annoying when, say, changing the hue of a certain selected object. The dotted lines are too distracting to get a good feel for what it is going to look like. I find myself having to duplicate a layer then do the image adjustment on the selection area and turn the layer on and off to get a good idea of what it would look like with the adjustmen on or off.
Bottom line.... is there a way to toggle on/off these annoying dotted selection outlines?
Thanks in advance
I don't think there is a way to turn them off. However I would suggest you use the selection to copy and paste the part of the image in question into another layer and then do your adjustment there. Then you won't see the "marching ants" and you'll be able to easily revisit your adjustment if it needs further tweaking.
E
  • 1 month later...
I'm with Travis.
Copying to another layer is _better_, even if you have a way to hide the ants. You can make the adjustment, drop some oppacity, maybe erase a bit... Why would you want to give up this functionality and...
Yeah, use the selection as a mask on a modification layer and you can even change your mind about the adjustment settings days later. You can add or subtract from the affected area at will...
Also don't forget about smart objects and smart filtering.
The only thing thirty-seven times better than living sans ants is living non-destructively.
