problem with large scale landscape (terrain & grass)
LuckyST
I'm working on this hangar, and as u can see it's coming along quite nicely... but I'm afraid the look of the "grass" around it spoils it. This is just wip, but I have no idea what to do with the grass fields around it once the rest is done.
of course I'm gonna add trees here and there, but it's still going to look flat.
(I use max&vray)
thanks for your help. (also a tip on the road would be welcome as well :))
(I use max&vray)
The first problem is the size of your grass map - its also not very seamless, so it makes it look a little fake. I reckon if you fix that, add some nice plants, rocks and trees it will look great.
wow! that's awesome! is that grass 3d, or photoshop?
the area looks mostly like this... it's pretty dull even on photographs :D
http://upload.wikimedia.org/wikipedia/commons/d/d0/Autocesta_A11_%C4%8Dvori%C5%A1te.jpg
I've found this guy's blog, and I wonder if anyone knows how to make grass like this
http://www.myszko.com/3D/Stills/NormandyRoad.jpg
more of his work ( http://www.myszko.com/?page_id=86 )
Edited by LuckyST
i would not suggest a 3d geometry for grass for this kind of camera angle
It will still look all flat. The images that other people have attached in this threa, if you notice, are eye level and close upimages. 3d grass looks nice in that. But for an aerial view try mixing 2 - 3 maps using a procedural map like noise or smoke for mask or maybe you can make 1 on your own in photoshop.
Try it. ur tiling will go away once u play with mix maps/blend materials.
Hope that helps
Thanks
Your grass lokks much better now. well done. so how did you do it then just procedurals? i think your road may be a bit shiny, unless its wet then i would probably be wrong haha.
photoshop:
1) I took bunch of high res satelite photos (randome ones), and made a 2x2 km large ground texture.
2) I made another high res detailed map of the ground (10x10 m).
max:
3) after that, I made the ground plane (2x2 km) with 100x100 divisions.
Added a displacement with the "satelite map" in the slot.
That created some relief in the ground plane. I then edit polyed it, and painted on some more relief in the plane.
max materials:
4) I then used "composite" to make a texture that would have the satelite image as the base, with high res grass on top of it as the difuse.
I also added grass "bump map" to the material @400 to add it some more noise.
here's a image of the settings
as for the road... didnt get to tweek it back then. Now it's all tweeked out. I've even added some trees...
Edited by LuckyST
  • 1 year later...
