markf Posted December 12, 2009 Share Posted December 12, 2009 I want to edit the 3dsmax.ini file so that the select by name dialog is the older version. I have done this for max 2009 but can't find it in Design 2010. The SceneExplorer = (x) line seems to be missing form the 3ds.ini. Has this been moved or is it not something that can be changed anymore or...? Thanks for any help Link to comment Share on other sites More sharing options...
Tim Nelson Posted December 13, 2009 Share Posted December 13, 2009 It should be there...I was able to do it in 2010, although at the moment I can't remember the exact directory that I found the .ini in. Link to comment Share on other sites More sharing options...
markf Posted December 13, 2009 Author Share Posted December 13, 2009 I found the file in Documents and Settings\User\Local Settings\Application Date\Autodesk\3dsMaxDesign\2010\enu There I find the 3dsmax.ini file. I open the file with notepad and all the various settings are there. I cannot find the SceneExplorer= line. Has it been renamed? Link to comment Share on other sites More sharing options...
Tim Nelson Posted December 13, 2009 Share Posted December 13, 2009 Ahh, ok, try this. In the enu folder, there should be a 'defaults' folder. Inside should be a file called currentdefaults.ini. You should be able to find it there. Link to comment Share on other sites More sharing options...
markf Posted December 13, 2009 Author Share Posted December 13, 2009 I have 2 folders under the defaults folder. DesignViz.mentalray and Max.vray Both contain a CurrentDefaults.ini file. I use Vray abd have Max set to start with that. The CurrentDefaults.ini file in the Max.Vray folder has the current date. That file, however, does not have the SceneExplorer= line. The DesignViz.mentalray does have the SceneExplorer= 0 line, but the date on the file is pretty old, I don't use mental ray (yet) and I'm sure that file is not being referenced by Max. I tried changing that DesignViz.mentalray SceneExplorer=0 to 1 but it, predictably, had no affect. Thanks for trying to help me figure this out. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted December 13, 2009 Share Posted December 13, 2009 I think you can just add that line to the ini file if it is not present, and then it will work like you want. I am not at my production computer, so I don't know for sure. Link to comment Share on other sites More sharing options...
ivorip Posted January 18, 2010 Share Posted January 18, 2010 (edited) I wrote this script since they made the scene explorer as default. Just run this script and it'll toggle between the two. Tested with max,mray,vray defaults. There's probably a more elegant way, but I couldn't find a location in max where it stores that value. render_type=pathconfig.strippathtoleaf (getINISetting (getmaxinifile()) "Directories" "Defaults") max_defaults = (getdir #maxdata) + "defaults\\" + render_type + "\\currentdefaults.ini" se_result = getinisetting max_defaults "Scene Explorer" "SelectByNameUsesSceneExplorer" if se_result == "1" then ( setinisetting max_defaults "Scene Explorer" "SelectByNameUsesSceneExplorer" "0" ) else ( setinisetting max_defaults "Scene Explorer" "SelectByNameUsesSceneExplorer" "1" ) Edited January 22, 2010 by ivorip Link to comment Share on other sites More sharing options...
