moonrathna Posted December 13, 2009 Share Posted December 13, 2009 Anyone could help me in v ray rendering am getting the reflection of sky in the rendered pic, am attaching the pic too.. [ATTACH]34989[/ATTACH] Link to comment Share on other sites More sharing options...
kippu Posted December 13, 2009 Share Posted December 13, 2009 attach a jpg please Link to comment Share on other sites More sharing options...
moonrathna Posted December 13, 2009 Author Share Posted December 13, 2009 [ATTACH]34990[/ATTACH] Dear Rippu, THis is the jpg for your info. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 14, 2009 Share Posted December 14, 2009 Use a falloff map in your reflection. Link to comment Share on other sites More sharing options...
moonrathna Posted December 14, 2009 Author Share Posted December 14, 2009 Could You pls Explain little bit clear, reflection of which material. I don want the sky reflection on floor. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 14, 2009 Share Posted December 14, 2009 Then don't make your floor material reflective. Or use a falloff map in the reflection slot to make it less reflective at certain angles. It might help if you post your material settings. Link to comment Share on other sites More sharing options...
moonrathna Posted December 14, 2009 Author Share Posted December 14, 2009 I don have any reflection for any materials in the scene, I used only standard material not vray Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 14, 2009 Share Posted December 14, 2009 You need to post more info about your scene, I have no idea what your question is even about any more. Link to comment Share on other sites More sharing options...
moonrathna Posted December 14, 2009 Author Share Posted December 14, 2009 In my scene I used purple sky and that color is reflecting on floor and all pillars. Do I need to change any Vray render settings All my materials are standard one. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 14, 2009 Share Posted December 14, 2009 Firstly it is better to use the Vray Material than standard for Vray as it is more optimised for that renderer. Secondly if there is no reflection in your material then it cannot be reflecting your sky. What is actually happening is that the material is being coloured by your skylight. If you shine a purple light on something it will look purple. Incidentally how have you set up your skylight, are you just using the Vray environment override? Link to comment Share on other sites More sharing options...
Nic H Posted December 14, 2009 Share Posted December 14, 2009 F1 is 3dmax help, id start there. Link to comment Share on other sites More sharing options...
nilariver@gmail.com Posted December 16, 2009 Share Posted December 16, 2009 Are you sure it is sky reflection, then why can't you rotate sky to avoid the sky reflection on the floor. There are chances(Not sure) changing materials also help you Link to comment Share on other sites More sharing options...
