Lots of Grass
Jason Matthews
Hey all! I've got an aerial image that I am about to begin that contains a lot of foliage but also a lot of open grass areas. Can any of you share your ideas for the larger grass areas? I'm using Vray but I doubt the displacement will be a good solution. Also can anyone share some tricks for the pass trees? Typically, I bring in the Xfrog trees and convert to vrmesh. Then spread like wild fire.
Thanks,
  • 1 month later...
  • 2 months later...
  • 2 months later...
[quote=glennn;305732
Has anyone seen a similar solution for doing lumpy gravel?
Do you mean something similiar to riprap? I have used Particle Systems in the past with great results, but now I pretty much use Forest Pro 3.
Riprap, driftwood, trees, scrub brush, and grass created using Forest Pro 3 and V-Ray proxies. 1000's of proxies...
