Kassner Posted April 30, 2003 Share Posted April 30, 2003 Hi everyone, Does anyone has a problem like this? http://www.cgarchitect.com/forum/filepush.asp?file=image_4.jpg I tried to increase the number of contour lines per surface on objects and higher values of smoothing angles before importing but I always get the same result. Anyone? Thanks, Kassner. Link to comment Share on other sites More sharing options...
Marq Posted April 30, 2003 Share Posted April 30, 2003 Hi, Those settings affect only the display resolution, not the actual mesh quality. In order to get smooth curved surfaces in acad you should increase the surftab1 and surftab2 values so you have more faces, but you have to do it before modeling the object, because those values can't be edited in acad afterwards. Regards Leo Link to comment Share on other sites More sharing options...
siliconbauhaus Posted May 1, 2003 Share Posted May 1, 2003 you need to set facetres to a higher value for extruded curves. surftab 1 and 2 only apply to meshes hope it helps Link to comment Share on other sites More sharing options...
STRAT Posted May 1, 2003 Share Posted May 1, 2003 you should be meshing curved surfaces up anyway instead of extruding them in autocad. Link to comment Share on other sites More sharing options...
nuno Posted May 1, 2003 Share Posted May 1, 2003 hi kassner, in the "import autocad dwg file" dialog box (in max) go to "acis options surface deviation" field, and decrease the value untill the desired result....this must correct your problem. i use to work in meters (units) and the value that fits my needs is 0.005 . best to you, nuno Link to comment Share on other sites More sharing options...
Kassner Posted May 5, 2003 Author Share Posted May 5, 2003 Now it works fine! I used higher values of FACETRES (8 to 10) when I generate 3DS in AutoCAD and 0.001 for ACIS DEVIATION to import DWG in MAX. Thanks for all replies! Link to comment Share on other sites More sharing options...
