bitmap quality option
pushkar.kundu
hi guys,
I have problem using 3ds max actually in top view port over plan i put floor plan through map
but i am not able to see actual floor plan since i have taken same size plan but its coming
distorted when i am rendering it is coming good but in the view port it is showing distorted
why can anybody solve my problem where i made mistake.i have been suggested to check bitmap quality option in view port configuration. but I am not getting this option can somebody tell me where i wiil get this option
thanks & regards
It sounds like you are using your plan as a bitmap in the view port background. Is this correct?
A better solution would be to make a 2d plane, and apply the bitmap to that. You do need to calculate the dimensions of the plane to apply the floor plan to, but it will work better than trying to use the bitmap as an underlay in the viewp ort background
