MegaPixel Posted December 16, 2003 Share Posted December 16, 2003 I've been searching around on the Internet for the Mpeg-2 Codec so that I can create movies from MAX directly to it. So far, I have found only Mpeg Programming references and false download links. Other then DivX which not many people have yet, is this the preferred codec to use for Internet and DVD use? What do you prefer to use? Thanks guys, Mega Link to comment Share on other sites More sharing options...
muzzy Posted December 16, 2003 Share Posted December 16, 2003 This is the one we use in school and media stuff. There is also a demo version which let you encode for 60 seconds. I don't know you can find mpeg2 encoder for free LSX Mpeg-2 [ December 17, 2003, 01:19 AM: Message edited by: muzzy ] Link to comment Share on other sites More sharing options...
Jim Mann Posted December 17, 2003 Share Posted December 17, 2003 You can get an MPEG extension for Quicktime direct from Apple at: http://www.apple.com/quicktime/products/mpeg2playback/ It costs $19.99 and enables you to export your animations to MPEG 4 but I can't be sure if it will export to MPEG 2. Jim Link to comment Share on other sites More sharing options...
MegaPixel Posted December 17, 2003 Author Share Posted December 17, 2003 Ok I have a second question for you then. Is Mpeg4 the new "Hip" codec to use or is it like DivX where not many people know of or use it yet? I'd gladly go to Mpeg4 if that is the new recommended format but it's discouraging that you have to pay for Mpeg encoding abilities. Thanks again guys, Mega Link to comment Share on other sites More sharing options...
Ernest Burden III Posted December 17, 2003 Share Posted December 17, 2003 Is Mpeg4 the new "Hip" codec to use or is it like DivX where not many people know of or use it yet?MPEG4 is DivX. MPEG4 is also what is used these days for encoding commercial DVDs. I think the early DVDs were MPEG2. And MPEG3 is also known as MP3, a format for squeezing the life out of music. I have been experimenting with various output for animations. With QT your best bet is still the Sorensen codec. Microsoft DV does not give you a codec choice, but I have found it to be a very good and fast encoder. I'm still trying different MPEG options out of Premiere, no set answer there for me, yet. Link to comment Share on other sites More sharing options...
Lester_Masterson Posted December 17, 2003 Share Posted December 17, 2003 And MPEG3 is also known as MP3, a format for squeezing the life out of music. Sorry, I don't mean to intrude, but I found some information on the history of MPEG. MP3's are actually MPEG-1, Layer 3. The MPEG3 format was initial intended for HDTV, but it was discovered that MPEG-2 provided the same features, so it was dropped. For for tidbits on MPEG, check out: http://www.sims.berkeley.edu/courses/is224/s99/GroupG/report1.html#_Toc447982111 Cheers Link to comment Share on other sites More sharing options...
Ernest Burden III Posted December 17, 2003 Share Posted December 17, 2003 was I right about anything I said? Link to comment Share on other sites More sharing options...
muzzy Posted December 18, 2003 Share Posted December 18, 2003 I tried both mpeg4 and mpeg2 outputs. For some reason, I never get the nice quality with mpeg-4 but with the mpeg-2, I got very nice quality results. I export it 720x486 without any pixelation or problem even in full screen. Last time I did mpeg-2 5 min of documentary about a library which includes real vieo shots and max animation. The file size was 150 mb in 720x486 resolution. Everthing was Ok for me. Another important thing is, when I export with quicktime sorenson 3 , computer can not play without stopping. I don't know because of file size or my mistake in encoding ( file size 800 mb in 720x480 5 min. lib documentary) I like the quality of Quicktime but never do it as a final result. I searched for different codecs like everybody. Now I am happy with mpeg-2 encoding. I can recommend without any hesitate. Link to comment Share on other sites More sharing options...
Jim Mann Posted December 21, 2003 Share Posted December 21, 2003 Originally posted by Ernest Burden: was I right about anything I said? Ernest, Yeah, I agree with your comment that "With QT your best bet is still the Sorensen codec." Jim Link to comment Share on other sites More sharing options...
C.Vestal Posted December 21, 2003 Share Posted December 21, 2003 Mega, Premiere Pro has be best Mpeg-2 Codec I have come across in a couple years. I have tried all those free ones... not to good and I do not have the time to test every setting, or basically become a "encoding expert". I want something that works great out of the box. Premiere Pro has about every format you could want to encode to. If you choose to do so, you can burn directly to a DVD disc. You can pick it up real affordably bundled with a Pyro firewire card.. Hope this helps my Indiana Neighbor Link to comment Share on other sites More sharing options...
MegaPixel Posted December 21, 2003 Author Share Posted December 21, 2003 Thanks Chris It sounds like the moral of this story is that you can't really go wrong with Mpeg-2 and that there is no good free way to obtain the encoder without the purchase of it alone or bundled with another program or piece of hardware. I really appreciate everyones input on this topic. I'll try to let you all know what I end up with. On a side note, I also noticed that there are some Avi. to Mpeg Convertors floating around out there also (Some of which are free). Not sure what kind of results they could yield but maybe it's worth looking into. Link to comment Share on other sites More sharing options...
C.Vestal Posted December 21, 2003 Share Posted December 21, 2003 You might want to try Windows Media Encoder. I have been using it to encode avi's to .wmv It does a great job at that and it is free!! I am not sure if mpg2 is a export format though.. Link to comment Share on other sites More sharing options...
muzzy Posted December 22, 2003 Share Posted December 22, 2003 Mpeg-2 is encoding/comprassion method like divx. Your final file is avi at the end. Link to comment Share on other sites More sharing options...
