VRAY interior lighting - window problem
Asgeijr
Hi!
I've just started working with vray and im attempting to do an interior light scene "A". (Im using Rhino not 3Ds btw)
I just can't figure out how to get the windows lighted as in "B".
Im using rectangular lights outside the windows, a pointlight in the middle of the room for further light, and a vray sun outside.
Any suggestions =)?
Thank you for the suggestions =)
I'm using the vray sun with sky, but the effect im looking for is like the windows in picture B.
If I use a emissive material layer on the windows I think it blocks the rays of sunlight and I won't get the effect of the illuminated window on the floor.
It seems like a simple task since I haven't yet come across it in any tutorial.
Any suggestions in what to do, or where to find a good tutorial on lighting interior or exterior is more than welcome =)
As aaron said put a vray sun in and add the default sky as a starting point, you can then try and add a vray light (plane) right behind glass
Make sure the plane is set as a sky portal.
Also check your glass settings. Is it transparent enough? Do you have affect shadows checked?
