mareck82 Posted January 4, 2010 Share Posted January 4, 2010 HI everybody, 1) After re-importing a FBX file from Revit to M.Studio all the Materials of the Multimaterial Objects are renamed automatically - and I have to reassign them all over again - How can stop Maxwell renaiming them every time I refresh my project? ALSO: 2) The imported FBX file has a wrong unit scale in M.Studio - The objects are 3 times bigger than in Revit - even if the units in Revit are set correctly to meters (import in 3d max works correctly!)- There is no adjustment to set the scale manually like for DXF!? 3) If instead of FBX I import a DXF file from Revit to Studio, the multimaterial Objects (windows rtc.) are just blocks and I can only assign 1 Material for the whole Objekt? I searched the whole net and tried everything within Revit and M.Studio for a week now but I see no solution for a good direct workflow between Revit and M.Studio for the moment Thanks a lot in advance PS.: I don't want to use the 3d max plugin Link to comment Share on other sites More sharing options...
Macer Posted January 4, 2010 Share Posted January 4, 2010 Can't help you with the maxwell stuff, but I know that Revit exports FBX in imperial units no matter what units you have set in Revit. Just rescale once you are in your next software package. Hope this helps? Link to comment Share on other sites More sharing options...
