Ausmax Posted January 6, 2010 Share Posted January 6, 2010 (edited) Hello, I can't seam to weld two vertices using a spline. i have a simple line and I am trying to connect an arc to it. The line has been attached to the the arc so that the line and arc are now one object, vertices are also fused. I have tried using bind also with no luck. When I convert to edit poly the spline disappears. Any thoughts, I would appreciate it! Edited January 6, 2010 by Ausmax missed detail Link to comment Share on other sites More sharing options...
hkbasravi Posted January 6, 2010 Share Posted January 6, 2010 I've had this problem before too. I thnk I solved it by adding another edit spline modifier on the object. But not sure why that happens. Link to comment Share on other sites More sharing options...
Ausmax Posted January 10, 2010 Author Share Posted January 10, 2010 I've had this problem before too. I thnk I solved it by adding another edit spline modifier on the object. But not sure why that happens. Ok, thanks Link to comment Share on other sites More sharing options...
