never_giveup Posted January 8, 2010 Share Posted January 8, 2010 hi, this is the first time I have a post here. I have used Vray render for few days but I always have a problem is there is a litte yellow or oragane collour in my image and it has some blur. I don't know why? Everything in my image is low and for test render. I hope everyone here can help me find out my problem. Thanks and good day Link to comment Share on other sites More sharing options...
bobaki Posted January 8, 2010 Share Posted January 8, 2010 Hi Never Give up, i hope this helps so give it a try . I am pretty new at the moment in architectural stuff...If you are using Autodesk maya.. Select the object that the material is assigned to and then go to its attributes and Scroll down to Mental Ray tab and look for Photo Attributes.. Uncheck the Derive From Maya and change the sliders for change in you scene.. Link to comment Share on other sites More sharing options...
never_giveup Posted January 8, 2010 Author Share Posted January 8, 2010 Hi Never Give up, i hope this helps so give it a try . I am pretty new at the moment in architectural stuff...If you are using Autodesk maya.. Select the object that the material is assigned to and then go to its attributes and Scroll down to Mental Ray tab and look for Photo Attributes.. Uncheck the Derive From Maya and change the sliders for change in you scene.. Thanks for your help . But I'm using 3ds max and Vray. Good luck to you Link to comment Share on other sites More sharing options...
bobaki Posted January 8, 2010 Share Posted January 8, 2010 ah damn ....sorry couldnt be any of help..lol I wish you luck with ur scene..I think Max would have the same material attributes to fix the issue u are having..I think it has got to do something with the material of the seaters and the floor.. Cheers Bobak Link to comment Share on other sites More sharing options...
never_giveup Posted January 8, 2010 Author Share Posted January 8, 2010 ah damn ....sorry couldnt be any of help..lol I wish you luck with ur scene..I think Max would have the same material attributes to fix the issue u are having..I think it has got to do something with the material of the seaters and the floor.. Cheers Bobak that's allright . I have a thought like you that walls and floor will absorb the light from the the Vraylight and it makes some yellow or orange collour in my image but I have tried many darker materials it also have the same problem. I' waiting for pro guys here can help me Link to comment Share on other sites More sharing options...
njoco2 Posted January 8, 2010 Share Posted January 8, 2010 Hi Kiet Try lowering the saturation level under Vray Indirect Illumination tab. The default value is 1. This should reduce the color bleeding. Good luck Link to comment Share on other sites More sharing options...
never_giveup Posted January 8, 2010 Author Share Posted January 8, 2010 Hi Kiet Try lowering the saturation level under Vray Indirect Illumination tab. The default value is 1. This should reduce the color bleeding. Good luck Thanks:), I will try your way. Link to comment Share on other sites More sharing options...
Tommy L Posted January 8, 2010 Share Posted January 8, 2010 The blur is due to your AA settings. Im guessing you have the default AA filter (Area). Try disabling the filter and raise the min/max rates. The color bleed is a matter of personal preference. However, if you are using a physical Camera then you could try changing the white balance to give warmer or cooler tones. You have more control doing color correction in post though, either in Photoshop or Aftereffects. Link to comment Share on other sites More sharing options...
never_giveup Posted January 9, 2010 Author Share Posted January 9, 2010 The blur is due to your AA settings. Im guessing you have the default AA filter (Area). Try disabling the filter and raise the min/max rates. The color bleed is a matter of personal preference. However, if you are using a physical Camera then you could try changing the white balance to give warmer or cooler tones. You have more control doing color correction in post though, either in Photoshop or Aftereffects. Thanks Tommy L, like you said, I have used the default AA Fliter (Area) for my image, so I will try with your way good day to everyone Link to comment Share on other sites More sharing options...
