chow choppe Posted January 11, 2010 Share Posted January 11, 2010 Hi how can i get vertices of spline into one plane. right now theye are shifted in 3d. in poly u can use Make planar to get vertices onto 1 plane is theer anything like that in splines? thanks Link to comment Share on other sites More sharing options...
stee Posted January 11, 2010 Share Posted January 11, 2010 Select all vertices and scale in the z axis (or other axis, depending on which axis you want them). Keep scaling down, down, down, until they're flat. This may not result in them being in the exact same plane, but extremely close to it. Someone else may have a better suggestion, but this is what I use mostly. Link to comment Share on other sites More sharing options...
kippu Posted January 11, 2010 Share Posted January 11, 2010 did you try glue? from itoosoft? Link to comment Share on other sites More sharing options...
jackbird Posted January 11, 2010 Share Posted January 11, 2010 stee said: Select all vertices and scale in the z axis (or other axis, depending on which axis you want them). Keep scaling down, down, down, until they're flat. This may not result in them being in the exact same plane, but extremely close to it. Someone else may have a better suggestion, but this is what I use mostly. Or pick NU scale, and 'use selection center'. Then type 0 in the Z scale transform type-in. Link to comment Share on other sites More sharing options...
