CHE Posted April 25, 2002 Share Posted April 25, 2002 Yes! It's me again. This time I have a question about Solids under AutoCAD. Right now, I'm working in a 3D model of a house. I have several arcs and circular shapes (which I extruded from polylines). So I'm trying to make them look smooth and nice but I haven't been successful. I have tried to fix this by changing the Isolines parameters, but I still get these polygonal arcs and shapes. So I was wondering if anybody knows how to fix this problem. I'm using AutoCAD 2002 full version. Thank you guys. [ May 01, 2002, 01:06 PM: Message edited by: CHE ] Link to comment Share on other sites More sharing options...
CHE Posted May 1, 2002 Author Share Posted May 1, 2002 Well. it seems that Facetres (value 10) fix that problem (I have the Isoline value set up to 50). I'll give it a try later on. I'm kind of interested in how this is going to work when I import my file into VIZ. I'll let y'all know.. [ May 01, 2002, 03:08 PM: Message edited by: CHE ] Link to comment Share on other sites More sharing options...
Tripp Posted May 1, 2002 Share Posted May 1, 2002 Go to Tools, Option, Display. There you can set the levels for Arc and Circle smoothness, Segments in a polyline curve, Rendered object smoothness and Contour lines per surface. Bump these levels up and then reset the shademode to see the changes. However, whenever I import arcs from AutoCAD to VIZ I usually don't extrude them until I'm in VIZ. I usually have more control over them then. (Of course, I'm using VIZ 2.0) Tripp web page Link to comment Share on other sites More sharing options...
cgnquema Posted April 16, 2008 Share Posted April 16, 2008 using a REGEN command most probably, a great help but and take note that autocad is not totally designed for 3D modelling. try to use autodesk inventor or solidworks Link to comment Share on other sites More sharing options...
Onslaught Posted April 22, 2008 Share Posted April 22, 2008 using a REGEN command most probably, a great help but and take note that autocad is not totally designed for 3D modelling. try to use autodesk inventor or solidworks If AutoCAD was not designed for 3D modeling, then why are there so many people using it? http://www.cgarchitect.com/vb/10514-what-3d-software-do-you-use.html Link to comment Share on other sites More sharing options...
neko Posted April 22, 2008 Share Posted April 22, 2008 using a REGEN command most probably, a great help but and take note that autocad is not totally designed for 3D modelling. try to use autodesk inventor or solidworks not a very good post to introduce yourself to the forum. first of all, the original question was six years old, so i'm guessing he doesn't really need your help anymore. secondly, where do you get the idea that autocad is not designed for 3D modeling ? do you even use it ? i'm guessing from your poor response, the answer is likely not. if so, then my advice is to read more posts and educate yourself before you make suggestions like that. Link to comment Share on other sites More sharing options...
cgnquema Posted April 22, 2008 Share Posted April 22, 2008 sorry if my experience was not good enough coz based on what I used before from AUTOCAD REL 10 up to REL 2000 way back 1996-2000 i personally trying to extrude a poyline in a spiral mode but it didnt work, i guess you can make it. and one more.,,,it so messy for me (well based on what i know if youre making a 3d design and using a PS & MS its so messy and I have to check the DIMLFAC just to make it sure that nobody's trying to make a CHEAT (dynamating the dimension) from the orginal dwg thnx for your concern, expert regards autodesk inventor (assmbly dwg ultimate solution) inventor modenot a very good post to introduce yourself to the forum. first of all, the original question was six years old, so i'm guessing he doesn't really need your help anymore. secondly, where do you get the idea that autocad is not designed for 3D modeling ? do you even use it ? i'm guessing from your poor response, the answer is likely not. if so, then my advice is to read more posts and educate yourself before you make suggestions like that. Link to comment Share on other sites More sharing options...
cgnquema Posted April 23, 2008 Share Posted April 23, 2008 well it depends on what disciplined they used. for a simple floor plan design with matching HVAC,ELECTRICAL, ARCHI, STRUCTURAL etc etc etc etc etc LAY-OUT (thru layering) this is most widely used for construction design but when it comes to 3D (take note to my buddy expert) well you can ask him HINDI DESIGN ANG AUTOCAD PARA SA 3D and for my BUDDY EXPERT i have one question??? if you have 4 UNEQUAL SIDES (IRREGULAR SHAPES) how to get the center????????? but if u forcing me to give u an answer ill try thnx inventor If AutoCAD was not designed for 3D modeling, then why are there so many people using it? http://www.cgarchitect.com/vb/10514-what-3d-software-do-you-use.html Link to comment Share on other sites More sharing options...
cgnquema Posted April 23, 2008 Share Posted April 23, 2008 for 4 unequal sides (irreguar shapes) and ill give you an answer in a professional manner heheheehehe thnx my buddy expert regards inventor not a very good post to introduce yourself to the forum. first of all, the original question was six years old, so i'm guessing he doesn't really need your help anymore. secondly, where do you get the idea that autocad is not designed for 3D modeling ? do you even use it ? i'm guessing from your poor response, the answer is likely not. if so, then my advice is to read more posts and educate yourself before you make suggestions like that. Link to comment Share on other sites More sharing options...
Onslaught Posted April 23, 2008 Share Posted April 23, 2008 well it depends on what disciplined they used. for a simple floor plan design with matching HVAC,ELECTRICAL, ARCHI, STRUCTURAL etc etc etc etc etc LAY-OUT (thru layering) this is most widely used for construction design but when it comes to 3D (take note to my buddy expert) well you can ask him HINDI DESIGN ANG AUTOCAD PARA SA 3D and for my BUDDY EXPERT i have one question??? if you have 4 UNEQUAL SIDES (IRREGULAR SHAPES) how to get the center????????? but if u forcing me to give u an answer ill try thnx inventor Sorry kabayan, but I disagree, but that's my opinion. If you're not happy with CAD then so be it. Link to comment Share on other sites More sharing options...
cgnquema Posted April 23, 2008 Share Posted April 23, 2008 its ok ibat iba ang opinon ng tao pero kung masusubukan mo ang ibang software na talagang pang 3D magugulat matagal ako sa AUTOCAD kya nakita ko ang diperensya thnx kabayan Sorry kabayan, but I disagree, but that's my opinion. If you're not happy with CAD then so be it. Link to comment Share on other sites More sharing options...
Horhe Posted April 23, 2008 Share Posted April 23, 2008 its ok ibat iba ang opinon ng tao pero kung masusubukan mo ang ibang software na talagang pang 3D magugulat matagal ako sa AUTOCAD kya nakita ko ang diperensya thnx kabayan Yo no entiendo una obra que acaba de escribirse. Link to comment Share on other sites More sharing options...
Onslaught Posted April 23, 2008 Share Posted April 23, 2008 Yo no entiendo una obra que acaba de escribirse. Sorry Horhe, I think he's new here. http://www.cgarchitect.com/vb/4587-forum-rules-user-agreement.html Link to comment Share on other sites More sharing options...
cgnquema Posted April 23, 2008 Share Posted April 23, 2008 yup im a new guy here, sorry if im mislead some of my statement, well seniority is a top priority in this forum not from a software that supposed to be,,,,,i guessed,,, im not belong here thanx for your support autodesk inventor Sorry Horhe, I think he's new here. http://www.cgarchitect.com/vb/4587-forum-rules-user-agreement.html Link to comment Share on other sites More sharing options...
Onslaught Posted April 23, 2008 Share Posted April 23, 2008 Hey Kabayan, I think you misunderstood. It is important that you speak english in this forum as I have posted out in the image. That is one of the guidelines here. It is not about seniority, it's about being able to understand you so that the experts can help. Link to comment Share on other sites More sharing options...
