Chris Potts Posted January 13, 2010 Share Posted January 13, 2010 (edited) I think i having problem with screen view jump. I try explan here what i do:- In 3D max 2010 Design When I put new VRayPhysicalCamera on position face toward 3D building model then change Field of View tool zoom in to see fit between Show Safe frame that i was happy with that view. Problem is that screen view:- later when I decide try move little bit rotate pan camera that Field of View sceen zoom jump back sqaure one . Im not sure it is issue Graphic card problem or not. I'm new to Vray 1.5 recently. EDIT:- I did try test change to standard Camera with Mental Ray. It was fine normal & nothing wrong with it. I guess only on VRayPhysicalCamera has problem. Any idea? Edited January 13, 2010 by Chris Potts update Link to comment Share on other sites More sharing options...
hughie Posted January 13, 2010 Share Posted January 13, 2010 I have a similar problem, when I select an object the whole view sometimes jumps 10-25 px, figured it was a graphics card problem, I let autodesk know, with a bit of luck it will be fixed in the next update. Link to comment Share on other sites More sharing options...
