Sebree Posted December 2, 2002 Share Posted December 2, 2002 I have a plan with some extruded shapes. How can I get the lines to render in Autocad ? Link to comment Share on other sites More sharing options...
STRAT Posted December 2, 2002 Share Posted December 2, 2002 type in SHADE for a quick render, or type in RENDER to take you to the render screen options. Link to comment Share on other sites More sharing options...
Sebree Posted December 3, 2002 Author Share Posted December 3, 2002 this doesn't allow you to render lines. I can't see any type of options to allow you to render lines like in viz (renderable splines) Link to comment Share on other sites More sharing options...
quizzy Posted December 3, 2002 Share Posted December 3, 2002 just print/plot with the hidden line option.. type: HIDE for a viewport you have to check hide lines option in the properties of the viewport.. Link to comment Share on other sites More sharing options...
nuno Posted December 3, 2002 Share Posted December 3, 2002 or you can do a dxb file with plot, and then import it to acad in lines... hope it helps nuno ps: try the CREATEHLR command (it works in most of acad versions)but i think it is not a documented command. Link to comment Share on other sites More sharing options...
Wojciech Klepacki Posted December 3, 2002 Share Posted December 3, 2002 You can achieve better results when you set some autocad variables. At the command prompt type at first: DISPSILH and put value 1 - it hides annoying lines from faces than: FACETRES and press 4 or 6 (but not more than 10) - it gives you accuracy of shapes especially arcs, circles, etc. at complex models it can takes time to hide model so be careful with this value. Certainly you can than hide/plot it or just simply hide at the command prompt. Obviously this procedures work only wilth solids. Best regards. Link to comment Share on other sites More sharing options...
Kerry Thompson Posted December 3, 2002 Share Posted December 3, 2002 Hi Thanks for the dispsilh and createhlr tips. I have used sofprof command to create hiden line flat images like http://www.kta.co.nz/cga/reception_counter.jpg This image was created with the hidden lines in one block, on a hidden line layer and the forground block using continuous lines. Look in the AutoCAD help for more info on sofprof. Regards Kerry Thompson Link to comment Share on other sites More sharing options...
