sanmb Posted January 14, 2010 Share Posted January 14, 2010 Hi all, 1.I am facing the problems with black materials in vray,its not giving good results. 2.V-ray light materials not rendering. This was not the problem before. This is very urgent. Can anybody suggest ?? Link to comment Share on other sites More sharing options...
alias_marks Posted January 14, 2010 Share Posted January 14, 2010 maybe double check 2 things. Either have all your normals facing out, or make sure the affect back side is checked in the vray light material settings (*if that's the material you're using) Also double check that you don't have co-planar faces... Link to comment Share on other sites More sharing options...
sanmb Posted January 14, 2010 Author Share Posted January 14, 2010 Thanks, I checked it all. Still its problem. may be i have to go for virus scan. Link to comment Share on other sites More sharing options...
Brian Smith Posted January 14, 2010 Share Posted January 14, 2010 i doubt you will get any good help without better/more input on your part. you're not giving us much to work with. Link to comment Share on other sites More sharing options...
kippu Posted January 14, 2010 Share Posted January 14, 2010 i have a feeling he will come back really soon Link to comment Share on other sites More sharing options...
XITIJ412 Posted January 22, 2010 Share Posted January 22, 2010 1) for black_ Try it-go to v-ray material editor tick fresnel reflections. 2) for lightmtl_ I have red if i m not wrong ,also i have faced this prob. If u r using vray_sun sky,vray lightmtl will not render (try latest verson of v-ray may be problem will be solved) try second option is use standard material with self illu. Link to comment Share on other sites More sharing options...
aristocratic3d Posted January 22, 2010 Share Posted January 22, 2010 You need problem solved but you are not giving info, attached render and render set up any thing!!!!!!!! Link to comment Share on other sites More sharing options...
