VZKD Posted January 15, 2010 Share Posted January 15, 2010 I am a first time user of Vray and I have a few questions about a particular image I've been working on. I've done some research on blurry refractions and reflections and gotten some really good results using interpolation. But I've read that you should not use interpolation with animations. So my question is what could you use to get good blurry refrac/reflec for animations? Also in the image I've posted you can see some light leaks coming from under the running track. The geometry goes all the way through but for some reason it looks as though its stoping short. Is there a work around for this? Link to comment Share on other sites More sharing options...
BrianKitts Posted January 15, 2010 Share Posted January 15, 2010 There's no reason you can't use glossy reflection/refraction in animation.... it's just better to not use interpolation with it because it tends to cause flickering. So you're just going to get a hit on your render time by turning the interp off. (I cringe when I have to animate scenes with a large section of frosted glass like that because I know it's going to shoot my frame times right in the foot) As for the light leak that's probably just a matter of correcting your irradiance settings. What are you using for hemispherical subdivs & Interp. samples? Link to comment Share on other sites More sharing options...
VZKD Posted January 15, 2010 Author Share Posted January 15, 2010 Thanks for the reply. I think my Min Max rate might be to low what do you think? Irr. map Min rate -3 Max rate -2 Hsph. subs @ 50 Interp. Samp @ 20 Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted January 15, 2010 Share Posted January 15, 2010 Render the translucent/frosted material as a separate matte pass. Render your main scene with the railing as a straight glass. Then composite the two in post. Link to comment Share on other sites More sharing options...
XITIJ412 Posted January 25, 2010 Share Posted January 25, 2010 hi!!! Travis Schmiesing, would u pls.tell me how could I used vray render eliments in animation & composited in After Effect software. ??? pls.anyone can understand me in detail.??? thank u. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted January 25, 2010 Share Posted January 25, 2010 hi!!! Travis Schmiesing, would u pls.tell me how could I used vray render eliments in animation & composited in After Effect software. ??? pls.anyone can understand me in detail.??? thank u. If you are trying to render out a composite for a glossy glass handrail or floor, I would render everything else as a matte with a -1 alpha contribution, and save as a format that supports alpha. This will give you an isolated object, with a alpha for compositing on top. There are threads about full render elements, but I am not skilled enough with that process to really give advice on it. Link to comment Share on other sites More sharing options...
