dISTRIBUTED RENDER, vray spawner issue
Alvaro Ram.
The problem is that every time i lunch a test render or a region, i have to make sure to turn off ando on all the vray spawners en every node i use.
I have 3 nodes and the WStation. This only happens in max 2009 and vray 1.50sp2.
If i render without doing this, the node buckets render the previuos image, the previous texture or the previous light calculations.
Does someone know about this? :confused:
Thanks a lot
Al.
I am not sure at what iteration it was introduced, but the latest version has an option to automatically restart Spawner after a rendering has completed. I have not tested it, nor had to use it, but it sounds like it should take care of your problem.
Alternately, if you are using 3dsMax, there is an option to run a script after a rendering completes. You could write a script that shuts down Spawner, and relaunches it, and then have that run after the image completes.
Edited by Crazy Homeless Guy
Spelling Errors
I am nt sure at what iteration it was introduced, but the latest versio nhas an option to automatically restart Spawner after a rendering has completed. I have not tested it, nor had to use it, but it sounds like it should take care of your problem.
Alternately, if you are using 3dsMax, there is an optin to run a script after a rendering completes. You could write a script that suts down Spawner, and relaunches it, and then have that run after the image completes.
Thanks for the reply, ireally do not know how to write a script, but it should restar every spawner in the 3 pc farm.. doesn't it? Is that possible?
I cant find the option in vray to restar the spawner after every render
cheers
Alv.
I used to have the same problem but it went away after an upgrade of Vray was installed.
I'm using 1.50 sp2.... and there is no "restart slaves spawner at render end", in the DISTRIBUTED RENDER SETTINGS... may be i should try sp3 or the last version, waht i don't know which is.
Thanks
