pablo scapi Posted January 17, 2010 Share Posted January 17, 2010 (edited) Hello: I have just built a new workstation and keep the same render node as before. I went for the tedious process of installing and gonfiguring all software, net, etc. I did a first test to render trough backburner and after some issues with the map paths all seemed to be OK. Later on after the first initial test, i tryed to send a real work render and the all mighty "an unhandled exception ... bla bla" happen, i then try to send diferents files with the same result, then i tried to send a simple render for wich i build a basic scene from scrath, and it worked fine, if i save that simple scene, re open it and try to send it the error occurs. So i started a new project, merged all my scene into it, and load a render preset (from that scene) and it was OK, then the second time i tri to send a render ERROR again. Right now, that is the error patron i´m having, first job from a drawing started from zero OK, job from an allready saved file ERROR. I use Vray but the problem happens also with scanline renders. What the hell can be happening here. Some system specs. Workstation: Win 7 64bit Max 2009 Render node: Win XP pro 64bit Max 2009 Thank you Edited January 17, 2010 by octopus Link to comment Share on other sites More sharing options...
