malevy Posted January 22, 2010 Share Posted January 22, 2010 As shown in the pic i am trying to change the color of this texture but its been a while since i have used vray and cannot remember the process. Can someone help out and tell me what i need to do to change this from the original color to the new one as shown in the image. Link to comment Share on other sites More sharing options...
CJI Posted January 22, 2010 Share Posted January 22, 2010 You could open the Bitmap slot, down at the bottom there is the Output tab. You can control the colour in there using the Colour Map or RGB level, Offset etc, thats how i would do something like that. Link to comment Share on other sites More sharing options...
aristocratic3d Posted January 22, 2010 Share Posted January 22, 2010 Just set the images output level to .7 , thats it. Link to comment Share on other sites More sharing options...
erickdt Posted January 22, 2010 Share Posted January 22, 2010 Photoshop? Link to comment Share on other sites More sharing options...
aristocratic3d Posted January 22, 2010 Share Posted January 22, 2010 Nop. from material editor. chosen bitmap has an out put level of one. It should be set to .7 or so. Link to comment Share on other sites More sharing options...
erickdt Posted January 22, 2010 Share Posted January 22, 2010 That's going to perfectly shift the bitmap's coloration to the desired color? Link to comment Share on other sites More sharing options...
DanGrover Posted January 22, 2010 Share Posted January 22, 2010 There's a colour correct map in Max now. Replace the bitmap with it, and tell it to keep the previous map as a sub map. Then you can hue shift, desaturate etc at will. Link to comment Share on other sites More sharing options...
