Salad Bar Model
ivanjay
Hello,
I am creating an interior scene (cafeteria) in 3ds max design 2010. We often have to model salad bars as we are a foodservice consultant. However, typically we take a box place it in our salad bar and just apply a map of a salad bar to it. This results in an extremely flat ugly texturing...
Modeling every single food item in a salad bar would create a nigthmare for rendering (peas, carrots, lettuce, tomatoes, etc.)
Any recommendations on how I can get it looking decent without killing my rendering time?
displacement or scatter. displacement can render pretty fast with certain settings, especially if just adding generic lumps to stuff (like pebbles, stones etc, or even a pile of mushrooms.)
All the stones in this render were done with Vray dis.placement:
http://2.bp.blogspot.com/_0GCIc31NK6E/SKsvm7YZKrI/AAAAAAAAABY/hjAAo9Z5sGU/s1600-h/2000.jpg
Wow, that looks terrific.... I have tried using displacement before for suspended ceiling and floor tile to give it that height perspective without any success.
Can you guide me a bit here? Would I make lets say 10 different boxes in my salad bar, each with a different color and just apply a displacement map to each one? How would I go about making such a displacement map?
You'd probably want to get a map of each one of the items that you want in your bins and then apply that to a plane with a fair ammount of segments (~20x20) and then apply either the VRay displacement modifier with a noise map or the standard displacement modifier (also with a noise map). The more segments/subdivision you have in your surface to smoother you displacement will be. That was probably the problem with you attempt a using displacment for a drop cieling.
E
E
so to summarize for mental ray (I dont have vray):
1. Create a plane for each salad item with roughly 20 x 20 segments
2. Apply a mental ray material with each ingredient as a bitmap in the diffuse slot
3. Apply a displacement map with a black and white noise input
That should do it?
I am not sure if anything is happening here...
I created a plane with a lettuce jpg.
I have 20 segments in each direction
I chose mental ray as my material type
In the displacement map I did the following:
Chose 3d Displacement as my map
Displacement Length - 1"
Extrustion Strength - 2
Extrusion Map - Noise
Black/White Color
Noise Type: Regular
Size = 5
High = 1 / Low = 0, Phase = 0
Here are the results and the settings I used to get them. I used the displacement modifier from within the modifier list.
E
A. that came out really good, putting me to shame with how easy that looks lol
B. I created the same settings and it seems to work nicely. Going to do a test render in a few. Of course now my lighting is screwed up... Grrrr
For such a large/ generic displacement wouldn't a noise modifier work better and use less memory? especially as these would be behind glass
If you were going to use a finer, more detailed displacement map then displacement would be the go
jhv
If I use a noise map it wouldnt give me the height adjustments....
I switched my exposure to logarithmic and boom, I have a salad bar... When back to mr photographic, black...
I would prefer to use mr photographic as it gives me much better control over the sunlight exposure (now I can't get rid of that blown out white from the sunlight...
  • 3 weeks later...
ivanjay, I am a foodservice equipment designer working with solidworks. I am currently trying to create a library of food items to render in my equipment. I have only been 3d modeling for a year or so and I am not familiar with any other rendering programs. any help you or anyone else on here could offer would be greatly appreciated. Chris
Chris, I am more than happy to help where I can but this is a pretty open ended statement :) There is a lot of areas up for discussion. What specifically are you looking for help on? I do not have any background with solidworks but as you can tell am familiar with CAD/MAX
