francosd Posted January 28, 2010 Share Posted January 28, 2010 Hi , i recently rescue 2 monitors and atached to my pc , now i have 3 displays in mi pc , my question is , can Move the viewports off max to anoter display? Link to comment Share on other sites More sharing options...
ihabkal Posted January 28, 2010 Share Posted January 28, 2010 Hi, I was wondering about this 2 days ago: imagine having the viewport fill your 1st screen with all commands on the 2nd. there is an expert mode in max that fills the screen with the viewport but hides all other panels and commands. But I need to keep both, any help is appreciated. Link to comment Share on other sites More sharing options...
JonRashid Posted January 28, 2010 Share Posted January 28, 2010 If your graphics card supports dual monitors just go to the settings and enable Link to comment Share on other sites More sharing options...
olly Posted February 2, 2010 Share Posted February 2, 2010 You need to unlock your UI and then you can drag & drop your tool bars and command panel where you like. Hope that helps? Link to comment Share on other sites More sharing options...
BrianKitts Posted February 2, 2010 Share Posted February 2, 2010 (edited) tool bars yes..... viewports no. but if you're running on three and two are equally sized you could stretch max across two monitors and split it that way if you really wanted. edit.... actually that's quite nice I may have to give that a run for a while..... Edited February 2, 2010 by BrianKitts Link to comment Share on other sites More sharing options...
