jofflumb Posted January 31, 2010 Share Posted January 31, 2010 Hi there. I plan model a house and render it, but then i need to place this render into a photo. so basically I have to create a 'how it would look' representation. What would be the best way to go about this so the house would fit in with the angles of the image? I will be using 3DS Max and either vray or mental ray. Any Advice?? THANKS Link to comment Share on other sites More sharing options...
jophus14 Posted January 31, 2010 Share Posted January 31, 2010 There are several good tutorials online regarding photo-matching. Here is one from Evermotion.org that is quite good. You could always follow the tutorial for camera matching in the 3Ds MAX help menu. A tutorial is a good way to go but depending on the photo you may have to just match it by eye. http://www.evermotion.org/tutorials_old/compositing/arch/ Link to comment Share on other sites More sharing options...
jofflumb Posted January 31, 2010 Author Share Posted January 31, 2010 Thankyou Jophus. seems quite a complex way of ex[plaining it, but ill have a deeper read through and hopefully it will help. thanks again Link to comment Share on other sites More sharing options...
Koper Posted February 1, 2010 Share Posted February 1, 2010 I were thinking of the exact same tutorial. I don't think you'll find a better one. gluck Link to comment Share on other sites More sharing options...
Ausmax Posted February 6, 2010 Share Posted February 6, 2010 I were thinking of the exact same tutorial. I don't think you'll find a better one. gluck Hi, I haven't done this type of work before, however- If you are familiar with photoshop you could create a simple perspective grid (series of lines) over the top of your background picture to help you eye ball the correct angles for the placement of your building. Import it into max and use it as a reference for you camera angles. Just an idea. Cheers Link to comment Share on other sites More sharing options...
Koper Posted February 6, 2010 Share Posted February 6, 2010 Yup, thats also one way of doing it. It all depends on how accurate you want it and how fast you have to do it. When i've got less than 45mins to spend on it I'll just eyeball it with perspective lines. Link to comment Share on other sites More sharing options...
