myusuf Posted February 1, 2010 Share Posted February 1, 2010 Hi, When I am rendering with VFB on and if the resolution is higher ie if its 1200x800 or more it shows on the blue strip of rendering window that vray frame buffer ( 50% of 1200x800). What does that mean? Does it not rendering with full resolution of 1200x800 Or some other reason. If the resolution is lower than that ie 800x600 or lower it shows Vray frame buffer ( 100% of 800x600). Please help me with this problem... I am using dual core with 2Gb of ram. I will appreciate any help. Thanks in advance.... Link to comment Share on other sites More sharing options...
easy3dsource Posted February 1, 2010 Share Posted February 1, 2010 That just means that you have the view in that window zoomed to 50% of your rendered resolution. If you scroll in and out with your mouse within that window, you'll see the image grow or shrink, and you'll see that percentage change accordingly. This is just done so that when you are rendering a shot that is a higher resolution than your monitor, it automatically fits the entire image on your monitor. Link to comment Share on other sites More sharing options...
