heni30 Posted February 2, 2010 Share Posted February 2, 2010 Hi, I'm playing around with exterior lighting on a free online model and I am using vray sun with vray sky in both the max environment slot and the vray envronment slot (value of .3). I set the sun low and get a nice yellow tone but when I put the sun up high the sky is staying too dark like there's a tornado approaching. Any ideas what might be causing this? It's my first experimenting with vray sun and I'm not real familiar with it's parameters. Any comments on lighting on building? Thanks! Link to comment Share on other sites More sharing options...
BrianKitts Posted February 2, 2010 Share Posted February 2, 2010 The vray physical sun and sky requires working utilizing Linear Work Flow and proper gamma correction. tons of threads on here of those learning the same thing you're facing. Link to comment Share on other sites More sharing options...
anejo Posted February 3, 2010 Share Posted February 3, 2010 Not sure if this help, but have you looked at the 3dats tutorials on vr exteriors lighting? http://www.3dats.com/free/ Link to comment Share on other sites More sharing options...
heni30 Posted February 3, 2010 Author Share Posted February 3, 2010 Thanks! I did find out how it works. It's just a chore sloshing through scattered threads. First you put your vraysun into your scene and put the vraysky in the environment slot. At this point the sky will be tied in to the sun; lower sun = more yellow sky, higher sun = bluer sky. Next you select a material in the material editor and choose vraysky for type of material. There will be a set of parameter for the vraysky materials. Choose "manual sun mode". Drag this material over to the Environment Map slot (Instance). Now you will have two separate controls. The vraysun parameters will affect the lighting on your building and the vraysky parameters (in manual mode) will affect the color and intensity of your sky separately. The attached images illustrate this by showing the building lit by the same vraysun - one has the vraysky tied to the sun; the other has the sky controlled via the material editor. Link to comment Share on other sites More sharing options...
