Creating a good fluffy rug in mental ray
Stan Zaslavsky
Hi all,
is there a good tutorial on how to create a nice looking furry rug in mental ray?
(maybe something that will look like this: http://www.housetohome.co.uk/imageBank/cache/c/Clocks8.jpg_e_c05121baa6f7e87f42266c0662e4a480.jpg)
i've tried the hair and fur modifier - but it didnt work too well for me and it took forever to render.
thanks for your help.
Thats a great question, all the good carpet renderings that i have seen are done with Vray. I would also like to know how to do fluffy rugs in mental ray. I have tried to play around with the hair and fur modifier, and like you, i was not successful.
I think that the hair&fur modifier can produce good results when you get the hang of it. I found out that if you convert the hair into mesh(tool rollout) it greatly reduces the render times,but it will greatly increase the scenes polygon count so it maybe best to have the rug on a different file and import it as a mr_proxy into your scene.
i've worked it out - slightly different method - but similar in some ways.
i used a model of a grass patch, applied a shaggy rug material, made it into a proxy
and then i arrayed it across the top of a base volume box - and then render.
i tried out the scatter for mr proxy - but it wasnt working for me as well as i wanted.
the above is lots quicker to render than hair&fur - so i'm happy
thanks again for all your comments
its looking pretty good, the only things i can comment on atm are the cushions (i think they need more creases??)
and the image seems slightly 'cyan-y'
just a slight colour balance adjustment in photoshop should sort that out.
i know a blue cast is a natural phenomena and all that but the reflections in the floor etc look a little too blue
hope it helps.
looks good though
Hi all,
i've tried the hair and fur modifier - but it didn't work too well for me and it took forever to render.
Messing with the hair and fur modifier today to see if I could replicate the carpet in the referenced jpeg. I am getting there.
I need to shorten the length of the hairs, and try and get them more "tufty" feeling, and I might have it.
This was rendered with Mental Ray, but with no FG or GI. RAM consumption is still very high though. Still to much for a straight production render, but might be useful if comped in.
Hi all,
Lazar - now thats a great fluffy rug :) - a little too fluffy for my liking, how long did this image take to render out? i assume you used MR?
And Travis - your rug is even fluffier ;) - you mention that RAM consumption was pretty high - what sort of time did it take to render this one out?
thanks for showing some of your works
I was running about 6.5gb's of RAM on it. Not sure on the render time, I was in the other room watching the Super Bowl.
I was also using Puppet Shaders for the materials in this scene. I am uploading the scene I based the settings of of. It renders fast. I would upload my scene, but I am a little embarrassed by the sloppiness of RAM consumption, and want to tweak it more.
The attachment has the Bone Studio setup scene, and you will need to Google for the Puppet Shaders if you don't already have them.
The scene was rendered in MR, on a Intel core2 quad(q9550@2.83Ghz).
render times were 5min40sec. for the first render, and 6min40sec. for the second.Everything on default settings, AA min 1/4 max 4 box filter,FG enabled/draft preset, GI enabled/default settings. Resolution 640x480px
And these render times are after converting the hairs into mesh....before that the render times were greater by 4 times.
  • 1 month later...
I know this has been dead a few months, but I just wanted some feedback if you guys are available... jsut a simple test scene to try and get ready for an upcoming project.
rendered with hair and fur using the instance node and a simple strand of fibre modelled with enough sub divs to allow it to curve nicely...
lit by photometric ies lights for the night shot
morning daylight... using MR sun and sky and photometrics...
i'm not sure if you can add an opacity mask to the base material to hide the edges a little bit .. looks like the hairs of the rug were stuck on a piece of thick material ..
but your hair&fur rug looks fantastic - good job.
how long did it take to render out?
Thx Stan... I see what you mean, will look into that I guess I could convert the hair and fur to a mesh and then either scale back the base or use an opacity map...
I would guess that it rendered in about 10 - 15 mins on 8 cores using ~1.2 gigs of ram. I can time it after easter when I give it another go...
