ihabkal Posted February 8, 2010 Share Posted February 8, 2010 Hi There, Just a question: anyone is usung high or very high setting for the IRmap in production? A friend of mine was using it, it was taking 15 hrs to calculate it, I told him it's not necessary, he said that his client expects the highest quality. Link to comment Share on other sites More sharing options...
BrianKitts Posted February 8, 2010 Share Posted February 8, 2010 If the client wants the highest quality, they should use a renderer who knows how to use the settings properly. He's just wasting his time with those settings.....depending on the scene that's probably total overkill, As long as he's got enough samples in the hemispherical subdivisions and interp. subs he would be able to render out with medium or possibly even a low settings and get a quality rendering (with little or no visible difference from his high preset) at probably a quarter of the render time. Does the scene have a lot of very small ornate details? If not I hold true to my original statement Link to comment Share on other sites More sharing options...
anindia Posted February 8, 2010 Share Posted February 8, 2010 If the client wants the highest quality, they should use a renderer who knows how to use the settings properly. He's just wasting his time with those settings.....depending on the scene that's probably total overkill, As long as he's got enough samples in the hemispherical subdivisions and interp. subs he would be able to render out with medium or possibly even a low settings and get a quality rendering (with little or no visible difference from his high preset) at probably a quarter of the render time. Does the scene have a lot of very small ornate details? If not I hold true to my original statement +1 Link to comment Share on other sites More sharing options...
braddewald Posted February 8, 2010 Share Posted February 8, 2010 +1 and an lol to Brian. Link to comment Share on other sites More sharing options...
ihabkal Posted February 8, 2010 Author Share Posted February 8, 2010 Does the scene have a lot of very small ornate details? If not I hold true to my original statement thanks for the response, I hope he will read it and get an idea. But also if you render at 6000 pixels wide or more those small details will show better and you won't need high settings... Link to comment Share on other sites More sharing options...
STRAT Posted February 8, 2010 Share Posted February 8, 2010 a friend eh? ok you need to know your software. you need to learn it and enable it to use your own settings. If you, er, i mean your friend, just relies on pressing the default settings then he'll not get very far very quickly. If i want uber high quality at any size, i'll never press a default setting. (i'll never press one anyway). you'll get so much more out of it if you spend a little time learning it Link to comment Share on other sites More sharing options...
Sawyer Posted February 8, 2010 Share Posted February 8, 2010 I guess if you dont know the settings and you have 15 hours to kill... Or if you are just lazy and can walk away then what he's doing will work. If you dont have 15 hours to waste then you need to learn the program. Link to comment Share on other sites More sharing options...
mahorela Posted February 9, 2010 Share Posted February 9, 2010 You could easily calculate a Brute Force primary solution in much less time than that. Then you would see some reasonable quality increases. I've never used the higher settings, my irmap is permanently set to low. I've ran plenty of tests and comparisons and there are all but imperceptible differences between the settings. There is a really interesting gnomonology tutorial by Christopher Nicholls called "speed vs quality" where he breaks down the correlation between light, AA, material and GI subdivisions. From what I understand if your irmap subdivs are very high and your AA settings are normal, the solution will only be as good as the AA settings anyway. Alex Roman uses low settings, I would wager to say that his work is higher quality than your friends. Link to comment Share on other sites More sharing options...
alexg Posted February 18, 2010 Share Posted February 18, 2010 that could also depend on the hardware he's working on. btw, isn't max usually crashes after 8 hrs? I forgot, but there's a time limit on previous max version, once you reached it, you are kicked out. Link to comment Share on other sites More sharing options...
