Dissappearing Recent File Menu
Bruce Hart
Hi all,
this is one of those annoying little things I've been wanting to fix for quite some time. In Max 2010 Design occasionally the recent file list drop down menu (from the big M) goes into a mode where the file list disappears when my cursor hovers over a recent file name - just before you have a chance to click on it.
Does anybody know how to fix this? I've tried graphics drivers, mouse drivers, altering the fly-out menu time - all to no avail. I don't have the steering wheel or view cube enabled. I have Vray installed if that makes any difference, but the same thing can happen with the AutoCAD menu.
Cheers
Edited by Bruce Hart
I don't know, but the exact same thing happens to me. The PC I'm on at the moment has the best (and the most expensive by far!) graphics card I've ever used, but the viewport and UI generally also seem the worse. I don't know if it' the card, UI bugs or what, but I get the same problem. It's horribly frustrating.
  • 1 year later...
I found by trial and error that if you move your cursor across the top of the column and then down along the extreme right
to the right of the push pins you can move up and down without the list items disappearing. Then when you get to the item
you want, just move left over it and click very fast. I did that this a.m. and after the first time the list stopped disappearing
but the problem might still be there when I turn the computer on again.
