Photometric IES light issue
bobmsn
hi, I'm using a photometric IES light and each time it renders I get the same effect, in that the beam seems to 'slice' off.
this only applies in the down beam, and I have tried different IES lights, a different wall, different wall textures, isolated the wall and the light - literally everything, even down to remaking everything concerned and changing the camera angle, yet I still cannot fathom out the problem.
if anyone could shed some light on this (pardon the pun) I would be highly greatful.
thanks, bob
I did a quick test and found what I always do with photometrics... I like them and get good results. I use vendor supplied IES if I can find out what's spec'ed for the project. No worries. Scanline or Mental. Near a wall or far away or sticking through so it shines on both sides. Rotated or not. I can not think of a way to duplicate your issue.
Can you post the IES file? or even the scene?
I haven't seen this before.
I agree with Peter. I've never had an issue. In fact, I have never seen anything to suggest that IES lights are "rubbish." Although most of my work (photometrically) has been done with mental ray and scanline with no problems. I wonder if it is a VRay issue.
I have access to VRay at work, so I'd like to give your file a shot across several render engines.
Stephen Thomas - you sir are a genius. thank you so much.
I had not even seen that tick box before let alone have a clue what it does.
if that is all it does then it's a worthwhile addition!
but thanks to everyone that took the time to help.
Edited by bobmsn
