RevitGary Posted February 11, 2010 Share Posted February 11, 2010 Does anyone know which "Common parameters" should be used when using mental ray? Do they do anything at all? Should they all be unchecked? Does the advanced lighting section apply to mental ray? Thanks!! Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 11, 2010 Share Posted February 11, 2010 Yes they do have affect, like "Render hidden objects" will render hidden objects, this caught me out recently. However the advanced lighting is for Radiocity and can be ignored. jhv Link to comment Share on other sites More sharing options...
RevitGary Posted February 12, 2010 Author Share Posted February 12, 2010 Does "displacement" also apply to bump maps and should be left on? Link to comment Share on other sites More sharing options...
jinsley Posted February 13, 2010 Share Posted February 13, 2010 bump mapping only affects the way light is reflected off of a material while displacement mapping alters the actual geometry. If you use displacement then you should leave it on... even if you don't, I don't think leaving it checked will alter your render times, or the performance of mental ray. An article on differences between bump, displacement and normal mapping... http://www.cgenie.com/tutorials/article/1-tutorials/5-introduction-to-bump-normal-and-displacement-textures.html -JI Link to comment Share on other sites More sharing options...
