Lights appearing black in occlusion pass.
heni30
Yes, using vray dirt.
I'm doing this for the 1st time so I'm not sure what to do for the lights.
I didn't change anything for the lights - just my regular vray plane lights.
If I do "emit on back side" won't they burn out the ceiling since they are a couple of inches from it? In this case it's not important because you only see a small strip of it in a uniform tone but if it was a 2 story space showing light coves and tone changes at the wall lines I would need it to not be burned out.
Thanks,
Yup,
For override material OFF if I hide lights and uncheck hidden lights in global, the lights are off in the rendering.
For the occlusion pass with the same set up but with override material ON
everything came out fine.
Is this always the case?
An occlusion pass doesn't have any lighting in it anyway, it just shows up where objects are touching one another. By far the easiest way to do an occlusion pass is to use the VrayExtraTex render element. Just add it then drop a vray dirt map into it, you can vary the settings by dragging it over to your material editor. Then it is just done at render time without the need to render twice.
Thanks for your help y'all (from Atlanta :))
Final attached heavily photoshopped (portal, all metal finishes etc.)
did u use spot lights in ur ceilings light? if so then i would say its not looking good there..
sound nice, can u make a tutorial on it? or u know any specific tutorial on this method?
btw friend of mine gave me this link and i found it very easy and useful..
http://scottdewoody.com/tutorial_occ.html
even i use Vray for render.
