win 7 hold pc when rendering...silly question?
Eric Sosa
got a new pc with windows 7 64bit installed for a couple of weeks ago, awesome working/rendering with win 7 64bits in a pentium 7 with lots of ram...yes, unfortunatelly only while I am close to the pc :rolleyes:.
apologizes if this is s silly question :o but....windows 7 stops max/vray after sometime if there is no activity ...what? :confused:.....despite having set the computer & screen to NOT stop ever. :(
kinda, if I do not move the mouse for over an hour, the pc goes to "sleep" and stops rendering or downloading, so when I come back I need to log myself in windows again.
anyone with a tip, please?
delete or move this thread if unsuitable for this forum
I suggest what mattclinch said... It seems windows 7 comes with an automatic power-saver that shuts down the computer if its left alone for too long [default setting is half an hour]. Its under control panel> system and security> Power Options. Odds are, the current power setting is "Balanced (recommended)". Click the "Change Plan Settings" button on the right, and you can then change the "put computer to sleep" setting to never. That will likely solve your problem.
thx to both matt's.
I have changed the "balanced" powersavings setup for the hard disk, screen, procesor, etc to NEVER switch off....it looks like it works, BUT; I still need to login after sometime and besides the renders seems to be hold again until I move the mouse!
I have checkt the powersavings several times and made sure the NEVER is on....tho still do not understand how come I need to log myself in after sometime....kinda very anoying.
I suppose the only way to check if the render stops if making the same huge render twice; one when moving the mouse often and the other one leaving the pc alone for long time, and then compare times....ughh :(.
