carlotristan3d Posted February 24, 2010 Share Posted February 24, 2010 Is there a way to cut a section in max similar to functions available in sketchup? I tried a camera with orthographic projection on and viewport clipping across the building. but i can't get a true section, only an orthographic view. Also how do I collapse a group into editable poly? Any tip would be much welcome. Link to comment Share on other sites More sharing options...
wasteland giant Posted February 24, 2010 Share Posted February 24, 2010 how I did them in the past (not that I do it often) was select the relevant geometry and applied a singular slice modifier. Not every elegant but yeah. Slice plus remove top or bottom. Link to comment Share on other sites More sharing options...
carlotristan3d Posted February 24, 2010 Author Share Posted February 24, 2010 how I did them in the past (not that I do it often) was select the relevant geometry and applied a singular slice modifier. Not every elegant but yeah. Slice plus remove top or bottom. thanks. grouped the whole bldg and apply a slice modifier. as you said, not very elegant but that'll do. thanks again. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted February 24, 2010 Share Posted February 24, 2010 There's a Soulburn script (my favourite of the lot, actually) to combine a selection into an object. Link to comment Share on other sites More sharing options...
