material by element, but with instances
Tim Nelson
I want to do something like the material by element modifier, but without attaching all of my instances into a single editable polygon. Is there a way to do that? Basically I want 4 or 5 different intensities of diffuse map to be applied to a bunch of instanced objects.
I guess I could do a random select script, and manually assign them to different materials. But I don't think that would give me as good of results since I'm trying to do 4 or 5 types.
select all of the objects you want to randomly assign materials to and use this script:
"for obj in selection do obj.material = meditMaterials[random 1 5]"
where the #'s 1 and 5 are the numbers of the slots in your material editor that contain the materials you want to use(they're numbered L to R on each row and top to bottom). So if you had the 5 materials you wanted to assign and they are in in slots 2-6 you'd change that to say [random 2 6] or whatever.
