braddewald Posted February 25, 2010 Share Posted February 25, 2010 (edited) I have several vray plane lights set up in a scene. They are doing everything correctly. However, there is a square shaped reflection from one of the plane lights that is appearing on a large glass panel in the scene. I don't want to turn off reflections, because I need them elsewhere and excluding the glass panel from the light doesn't seem to do anything about the reflections. What is the solution? Edited February 25, 2010 by braddewald syntax Link to comment Share on other sites More sharing options...
erickdt Posted February 25, 2010 Share Posted February 25, 2010 Could you turn off the affect reflections option within the VRay light? E Link to comment Share on other sites More sharing options...
braddewald Posted February 25, 2010 Author Share Posted February 25, 2010 That's a good idea, but like I said I don't want to turn off reflections because the reflections of that light on the floor is crucial. I only want to get rid of its reflections on that one object in the scene. Link to comment Share on other sites More sharing options...
braddewald Posted February 26, 2010 Author Share Posted February 26, 2010 Do you think its impossible? Link to comment Share on other sites More sharing options...
erickdt Posted February 26, 2010 Share Posted February 26, 2010 If it is possible I don't know how :-/ E Link to comment Share on other sites More sharing options...
Eric Sosa Posted February 26, 2010 Share Posted February 26, 2010 select the object, go to properties and exclude it from reflections...or whatever u want. u can do the same in object vray properties. Link to comment Share on other sites More sharing options...
dpcaltdcah Posted February 26, 2010 Share Posted February 26, 2010 did you try turning off 'affect specular' ? Link to comment Share on other sites More sharing options...
braddewald Posted February 26, 2010 Author Share Posted February 26, 2010 I need the reflection and specular to affect the rest of the scene, but not the glass panel. I guess I'll have to render the scene with affect reflections and affect specular turned both on and off and composite the two. Link to comment Share on other sites More sharing options...
dpcaltdcah Posted February 26, 2010 Share Posted February 26, 2010 instead of rendering the entire scene twice, could you just render that piece of glass separately? basically what you said but it would save you time... Link to comment Share on other sites More sharing options...
BVI Posted March 2, 2010 Share Posted March 2, 2010 Can't be done (GI engine and all), I haven't tried on the latest version of Vray, ill check later- dpcaltdcah is right. MR could do this. Link to comment Share on other sites More sharing options...
tommyjj Posted March 4, 2010 Share Posted March 4, 2010 can you just render a reflection pass on the glass and paint out the unwanted reflection? Link to comment Share on other sites More sharing options...
