jun_icoi3e Posted March 2, 2010 Share Posted March 2, 2010 Sorry if this is a newbie question. I have a i7 920 system 4gb ram with win7 64 bit i bought recently. I have install 3dmax 2010 64 bit and vray 1.5 sp3a. When i render a scene using vray, I can see my 8 cores in the task manager but none of them are running at 100%. I was wondering what could be the problem for this. Is it my software issue or my hardware configuration? Thanks in advance. Jun Link to comment Share on other sites More sharing options...
RenderStream Posted March 3, 2010 Share Posted March 3, 2010 (edited) The intel i7 920 is a 4 core CPU which has hyper-threading technology. If you have hyper-threading disabled and you examine the performance tab of the windows task manager you will see 4 CPU’s being graphed. When you enable hyper threading you will see 8 processors present. Hyper-Threading Technology delivers thread-level parallelism on each processor resulting in more efficient use of processor resources. It doesn't mean that your render times will double when enabled. Our tests showed a 27% speed increase when we enabled HT. The configuration was run 4 times at a room temperature of 72 degrees. So what you are seeing graphed in the task manager could be misleading since it is graphing 8 virtual cores when in fact you really only have 4 physical cores. I'm sure your hardware and software is running just fine. hope that helps, -joe Edited March 3, 2010 by RenderStream Link to comment Share on other sites More sharing options...
Grohu Posted March 4, 2010 Share Posted March 4, 2010 If you are using Light Cache make sure you set it to 8 passes. Not even sure if sp3 has that option but I know people were having same issues. Why don't you upgrade to sp4a btw? Link to comment Share on other sites More sharing options...
