thickly Posted March 9, 2010 Share Posted March 9, 2010 I need to wrap a texture across a curving wall - but can't figure out how to get it around the corner of the wall. I have a "box" UVW map on, but as soon as it hits a section of the curve it is treating it as another plane on the "box" and tiles the texture. The screen grab should pretty much convey my problem - basically I need the texture to wrap the wall as if there was a vinyl graphic applied to it. Any advice would be appreciated. btw...the geometry was created using a spline, giving it thickness, converting to editable poly and extruding. I did check the mapping coordinates option but didn't seem to have an effect - still needed to apply UVW coordinates. Link to comment Share on other sites More sharing options...
WAcky Posted March 9, 2010 Share Posted March 9, 2010 If you use a sweep or a loft to re-create this object then it should give correct mapping coordinates meaning you wont need a uvw map and the texture wont cut like that. Otherwise simply using a uvwunwrap modifier and referencing the help documents will get you out of this situation. Give it a try! Link to comment Share on other sites More sharing options...
