Rhino Forum
salty_dogs
i started using autocad as a student in '93, that was the dos r12 version. i didn't use the menus, and i think, like most dos kids, stuck with the keyboard shortcuts. i guess its a generational thing. the guy i work for (he's 65) can do simple math by hand faster than i can get the answer with a calculator.
anyway, the way i got comfortable with rino was to make it feel like autocad and i believe this was one of their intentions... to grab autocad users. i've never liked acad's solid modeler and have always used surfaces, so i found the equivalent surface building commands in rhino, 3dface, tabsurf, revsurf, rulesurf, etc. and used the same alias that i use in acad. control over polygon count/placement/edges is still an issue because at the end of the day, you still have to convert from the nurb objects BUT if your subject doesn't contain too many curves, it will do a pretty good job of simplifying planer areas.
why is it that autodesk has never, in the last 10 years (maybe more) improved on its surface modeler? are there add-on programs that you guys are using over the vanilla acad? from what i've seen/heard about viz/max, there are some pretty incredible polygon modeling tools now included. i just draw 2d shapes so much faster in acad than that crazy spline tool menu in viz. although i do like the idea of a smart object that can be redefined by changing parameters like step count or facet number.
other than the technical aspects of curve control points, degrees and weights, here's what i like about rhino over acad:
1.i can trim a surface
2.i can make a planer surface from planer lines (it knows to make openings with nested objects)
3.i can join surfaces to make a solid, use boolean commands, then explode into surfaces again.
4.i can extrude along a path
5.loft along cross sections.
6.use grip points
7.project curves(lines) onto surfaces
8.extract edges to build other surfaces
9.work in perspective
10.change my view pan/zoom/orbit without having to use a command (its all with the mouse and shift/control keys)
11.orbit my view, keeping the world z-axis vertical even when the construction plane is not set to the world position AUTODESK CAN GO TO HELL FOR NOT DOING THIS.
it goes on, i'm becoming a convert.
I do all of my work with Rhino/Flamingo. It's an amazingly simple, user friendly, and fast program. Flamingo, the render plug-in lacks a remotely decent material library which makes it appear to be really weak. However, with the right materials, you can have some very solid output. Its radiocity and photometric capabilities really shine too. Rhino 3 introduced blocks and workgroup networking along with a ton of bugs. The official release was more of a beta test.... but I really love this program and I'm surprised that others haven't realized its potential. Everyone seems curious about it... I would say the learning curve is about two weeks, at most. It needs a good integrated export option too, which is annoying especially when you're working on large projects and you need to combine models from different programs..
At any rate I would love to see a forum for Rhino/Flamingo.
-Joe
A rhino forum here would be nice but their official newsgroup is amazing. So many helpful people and the developers (and even Bob McNeel on occasion) are very active in the newsgroup. A lot of wishes of users get put into the service releases so the software evolves the way the users want. Where did PLJOIN go in ACAD2002 :confused:
I've come to realise that the two pieces of software I swear by, Rhino and VRay, both have excelent support and direct discourse between the developers and users...co-incidence?
A rhino forum here would be nice but their official newsgroup is amazing...I've come to realise that the two pieces of software I swear by, Rhino and VRay, both have excelent support and direct discourse between the developers and users...co-incidence?
I was very active in the pre-v.1 Rhino beta--it was the first public beta I ever saw. The whole developement process was end-user driven. Bob McNeel was very involved. I really feel like there is a bit of me in Rhino. As a company they have been very good to deal with for anything, including a lost serial number.
But perhaps you are right about not duplicating their forum. I should get active there again, I haven't shown up for several years.
(Flamingo) Its radiosity and photometric capabilities really shine too.
Accustudio (aka Accurender) derivative?
(Flamingo) render plug-in lacks a remotely decent material library which makes it appear to be really weak. However, with the right materials, you can have some very solid output.
Any examples u could post?
Hi fellow Rhino users. I've been 3d modeling for 3 yrs now, always on Rhino. I can't imagine using anything else. For what I do, It is superb. I design free form plastic parts; kayaks, toys, etc, Rhino outputs in iges format, used by most toolmakers. I also do a lot of 3d rendering for interior designers with Lightscape. Rhino is just perfect for Lightscape modeling, you convert your nurbs objects to polygons, and it gives you perfect 4sided polygons, perfect for LS. It also has layers, that transfer to LS using dwg.
As a modeler, Rhino is great. IMHO.
Francois
I design free form plastic parts; kayaks, toys, etc, [in] Rhino...I also do a lot of 3d rendering for interior designers with Lightscape. Rhino is just perfect for Lightscape modeling...
Would you post some images of Rhino/Lightscape? I would especially like to see some of the 'free-form' objects!
You can see my work at http://www.inno3d.ca, all done in Rhino.
There is something wrong with the URL for your webpage as entered in your CGA profile (at least it didn't work for me), I had tried to have a look after your first post. And as you typed it in just now also does not work without knocking off that comma after .ca
But I did get there. I especially like the stone house--very realistic.
  • 1 month later...
A Rhino Forum would be so Great !!! :D:D
You can count whith me if you open it Guys !!......I would be glad to share tips, resolve bugs, improve techniques and learn whith other rhino users, especially for architecture... Yes, usually, rhino users make pure object design, boats, or jewelery... I'd like to meet ppl who use it for architecture .... like me..
Bye
If the forum opens up, There will be many ppl pleased to participate.... Do you absolutely Need a Mod ? (Perhaps my question is naïve... :ebigrazz: )
[ July 21, 2003, 02:30 AM: Message edited by: Mike ]
