trensteel Posted March 16, 2010 Share Posted March 16, 2010 Looking for some help with tiling textures on maxwell 2. Im using a material called sandstone tile which I got from the maxwell website. The material needs to be applied to the floor in both the hallway and the W.C. I have managed to get the material to tile fine in the W.C, but want to same sized tiles, on a larger surface area in the hall space. When the material is applied to a larger surface, it looks all stretched! Each of the texture settings are the same for each texture. I have attached a quick render of the problem, and would be greatful if somebody could explain how to get the same results from the W.C floor in the hallway. The is also a screen shot of the material settings for the material. Link to comment Share on other sites More sharing options...
TheAllusionisst Posted March 16, 2010 Share Posted March 16, 2010 Set up projections/projectores custom for each surface. Link to comment Share on other sites More sharing options...
