zewanil Posted March 18, 2010 Share Posted March 18, 2010 Hi guys i am wondering if vray 2009 is working on 3ds max 2010 ? From now on , i have window 7 64 bit , I have done that so i could have more ram in the setting of vray ( dymamic memory limit ) . Its the first time will work with 64 bit , and i am wondering if i need a vray 64 bit or something like that thanks for lighting my question Patrick Link to comment Share on other sites More sharing options...
WAcky Posted March 18, 2010 Share Posted March 18, 2010 not sure what you mean by Vray 2009? Link to comment Share on other sites More sharing options...
zewanil Posted March 18, 2010 Author Share Posted March 18, 2010 thanks for replying vray 2009 = Vray_Adv_1.50_SP2_x86 i am also wondering .. can i install vray Vray_Adv_1.50_SP2_x86 64 bit and work with 3ds max 32 bit? ok i will clarify ... i have two different computer .. one at work and one at home ...i have upgraded my computer at home so i could amplify the dynamic memory limit higher then 3 gig ...by that ... i have change window xp to window 7 64 bit ... this will make my system with more RAM and then i will be able to render bigger image ... Can i work a file at home with 3ds max 2009 64 and then open it at work with 3ds max 2009 32 bit? so many question thanks a lot Link to comment Share on other sites More sharing options...
bzubrick Posted March 18, 2010 Share Posted March 18, 2010 thanks for replying vray 2009 = Vray_Adv_1.50_SP2_x86 i am also wondering .. can i install vray Vray_Adv_1.50_SP2_x86 64 bit and work with 3ds max 32 bit? ok i will clarify ... i have two different computer .. one at work and one at home ...i have upgraded my computer at home so i could amplify the dynamic memory limit higher then 3 gig ...by that ... i have change window xp to window 7 64 bit ... this will make my system with more RAM and then i will be able to render bigger image ... Can i work a file at home with 3ds max 2009 64 and then open it at work with 3ds max 2009 32 bit? so many question thanks a lot You will need a 64-bit version of 3ds max in order to install the 64-bit version of Vray. Link to comment Share on other sites More sharing options...
