Playdo Posted March 18, 2010 Share Posted March 18, 2010 I'm sure this would have been discussed before, so point me to to it if so. I'm fine with resolution in general but I need a better understanding on how map resolution works within Max. I take it resolution has nothing to do with the actual scale of the object but of the resolution that it takes up in the render? ie. a 10x10cm object would render out at the same clarity as a 100x100cm if they had the same res. map and took up the same amount of the render frame. If rendering a 1500x3000px jpeg and, say a mapped wall took up 1/3 of the render space. Would you aim to make that map 500x1000px? Link to comment Share on other sites More sharing options...
